DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
Wiltshs
Apr 27, 2017Guide
I have been trying to fix the same no internet connection issue and followed all the same steps as you. My main wireless router is a Netgear R8000 that the EX7000 connects too and had a firmware update a few weeks ago and I think this is the cause of the issue. DrCharlesForbin I would be very interested to understand what you have your EX7000 plugged into and might the cause be the same?
R8000 Firmware V1.0.3.36_1.1.25
EX7000 Firmware V1.0.0.50_1.0.102
Thanks in advance.
darkangel
Apr 28, 2017Tutor
Hi,
I have also recently bought the same model EX7000 and am getting the same internet no connection error even though my devices are able to connect to the internet via the EX7000 without issues.
I have managed to contact Netgear Support for help and they will be assisting me via phone to check out, though i don't really think there could be a solution immediately.
I had also mentioned about this communication to them and they should be aware of it since it is discussed in their Netgear community channel. Hopefully they will take serious action to resolve the problem soon.
Cheers.
