DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
darkangel
Apr 28, 2017Tutor
Hi,
I have also recently bought the same model EX7000 and am getting the same internet no connection error even though my devices are able to connect to the internet via the EX7000 without issues.
I have managed to contact Netgear Support for help and they will be assisting me via phone to check out, though i don't really think there could be a solution immediately.
I had also mentioned about this communication to them and they should be aware of it since it is discussed in their Netgear community channel. Hopefully they will take serious action to resolve the problem soon.
Cheers.
Wiltshs
Apr 28, 2017Guide
Darkangel - Yes its exactly the same issue I am having everything does work but just getting the image when you log in no internet. I did have a go at deleting the DHCP cope on my R8000 router and reboot and apply and had to force feed the MAC address to get it to work. Agree it’s a network address resolution issue, if I can get the family off the network for long enough I am going to do a full reset of the R8000 and the Virgin Media router. I know I do not have any cable issues or other hardware related issues.
Report back when I have done the above.
