DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
darkangel
Apr 30, 2017Tutor
I had a reply from Netgear after they had some confusion with my previous arranged schedule.
Don't think they are making sense...
I already told them that i am connecting my EX7000 extender to my Asus main router via LAN cable as an access point. Thereafter, i configured the EX7000's wifi to extend out my range. According to their manual, if we want to connect it as an Access Point, we should use a LAN cable to connect between the main router and the Extender right? Why are they now saying i should not connect via LAN? are they asking me to set up my EX7000 as a Extender instead of AP? Come on... Netgear...
Response from NETGEAR
Hi,
I had checked the previous response to the email Rhys sent out and the schedule you sent was 28 May 2017 which is way longer than we anticipated. We checked with you if that was the correct schedule and you confirmed it was so we cannot call you at an earlier time than that.
I believe it was where the confusion happened, we could have this scheduled at another time which you preferred.
Also, I would like to get your confirmation that you stated that the extender was wired to the Asus router.
This extender will only work as a wireless access point to be connected to the main router's Wi-Fi not through LAN. Its extender function will need to be configured the same way as the access point function.
Alex
Expert ID 8313
NETGEAR L2 Support Expert
Alex
Expert ID 8313
Wiltshs
Apr 30, 2017Guide
Agree makes no sense! As you rightly state the extender is created by wireless and access point by physical LAN and wired to the router, Netgear need to go and study their own manuals and kit!
Darkangel I need you to pursue this as far as possible and see if we can get a fix, point them at our posts there are more of us with the same problem.
Good luck and thanks in advance.
