DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
d0gg
May 03, 2017Apprentice
I am experiencing the same issue with the web-control of the EX7000 reporting no internet connection.
I tested and confirmed that I am in fact connected to the internet when I am connected through the EX7000. I achieved this by changing the SSID to a new name that is different from the R9000 and the other EX7000 in my network setup. (quick note, both EX7000 report no connection)
When I connect to the EX7000 I am able to use all internet connected software on my MacBook. So it is just an issue with reporting correct status (at least in my case).
I have attempted to drop back versions of firmware on both the EX7000s and the R9000. No change. I also just updated to a new firmware version, for the R9000, that dropped recently. This did not fix the issue.
One thing I can share, not sure if it is important or not. When I initially setup my network with the R9000 and the two EX7000s it was reporting correctly on the EX7000s. No changes were made to either router as far as firmware. (When I was installing the R9000 it forced an update of firmware, one back from the most current, but it was working after that). I am not sure when it fell to reporting incorrect internet connection status. The R9000 has always correctly reported that it has an internet connection.
