DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
NGGJ
May 07, 2017Aspirant
I also have the same problem. No solution as yet, but I am hoping someone might come up with a solution on this thread.
I have Virgin Media hub set up as a modem connected to a R8000 with a wired connection to an EX7000 as a WiFi extender.
R8000 firmware: V1.0.3.36_1.1.25 (updated last week)
EX7000 firmware: V1.0.0.50_1.0.102 (updated just now)
I did a belated firmware update on the R8000 because of the well publicised security issue a few months back. Thought I should check the status of the EX7000 this week.
Strangely, when I logged in, the EX7000 was already showing that I had 'no internet connection'; but I knew that wasn't case as I had more than one mobile device successfully connecting through it. So I thought I would update the firmware and hoped it would solve this error message. Bizarrely, after updating the firmware successfully on the EX7000, not only does it still report 'no internet connection', it is no longer able to 'check for updates', reporting the lack of internect connectivity as the reason (whereas, just minutes earlier it had managed a successful update over the same connection)!
I can still connect my mobile devices through the EX7000 and via the R8000 to the internet, so I am not suffering any loss of functionality. One odd aspect I can see is that the EX7000 is not recognised as an 'attached device' on the R8000. In the Basic display of attached devices on the R8000, all devices wirelessly connected to the EX7000 shows up as wired connections on the R8000. The EX7000 appears invisible to the R8000.
I am beginning to wonder if I should have just left everything alone and not messed with it!
Frantisek
Hello
Thank you for your quick reply and description. I am pretty often on my router, Fritz 7490, very common in Germany. And here I go from time to time on the Extender.
And today the problem! Nothing changed, no updates, nothing!
What happened, what's going on. I also tried everything possible: reboot, reset, reinstallation, different configuration ....
Nothing helped.
And:I have the extender for about 4 months, with the latest Firmware, NOTHING CHANGED! (also by Router not)Only hope remains.
With kind regards Frantisek- AJCrowley666May 07, 2017Guide
Out of curiosity what OS are people running, could this be OS related?
