DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
Wiltshs
May 08, 2017Guide
Same issue Virgin Media in the UK does not support IPv6 and sure this is not the issue anyway. Did have a look on my Netgear R8000 to see if I could bridge IPv4 to IPv6 but you cannot, only the other way around and not going to help you.
I still think it’s a call home feature at firmware level and could be as simple as a security certificate has expired at the Netgear end but would expect to see a HTTPS request go out on the firewall logs and I could not see this but that does not mean Netgear may filter this out for us not to see this?
Answer other posts – I have Kaspersky Total Security 2017 for AV and Windows 10 Creator Edition for desktop and Laptop but also same error message on Android tablet version 6.
AJCrowley666
May 08, 2017Guide
yeah i think the whole ip6 thing was a long shot but running out of ideas. i was going to say something about what do you expect when you use an internet providor that does not go all the way :-)
i can also see nothing on my router logs, i cleared them first so i started with a clean slate but so far nothing useful.
i am surprised by the lack of answers from Netgear as this may well be something very simple
- DrCharlesForbinMay 08, 2017Apprentice
Not a damn thing in my router logs.. not even trying to get out.
- AJCrowley666May 08, 2017Guide
same, i am now looking at the page source code to try and see whats going on, i can see the function call but cant seem to find any more
('body').msgload(); $('body').msgshow("Checking the Internet connection; please wait …"); $.ajax({ type: "POST", url: "ajax/get_internet_status", data "action=getStatus", dataType: "html", success: function(data) { if (data != "1") { $("#title_string").html("<i class='icon-errormark'>"); $("#title_string").append("Your access point has no Internet access. Check to make sure that your router has an Internet connection."); $("#cc_red_cross").addClass('redCross');
- FrantisekMay 08, 2017Aspirant
I GOT IT! :smileyhappy: True, it is related to IPv6. In my router FRITZBOX 7490 gives it the possibility to join them. And my IT provider supports them as well.:smileyhappy::smileyhappy:
IPv6 support IPv6 support IPv6 connectivity Native IPv4 connection (recommended) First, a native IPv4 connection is established. If a 6RD server has been learned via DHCP, a 6RD tunnel is established. Otherwise, an attempt is made to establish a native IPv6 connection (dual staThanks to all and much success!
Greetings from Germany
Frantisek
