DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
AJCrowley666
May 09, 2017Guide
Hi Frantisek
great news i think, can you confirm you no longer have the no internet connection message?
Frantisek
May 09, 2017Aspirant
Hi AJCrowley666
The Netgear Ex 7000 I have about 4 months, as access point, equal from beginning with the newest firmware. Everything went great, and very good signal.
All devices always well connected, without signal or speed drop. (1 PC with Windows 10, 1 PC with W7, Smartphones with Android).
And then I did not look so often at Netgear genius. Then I have on my PC Windows 10 updated to the latest version, as I noticed: no internet connection, although Internet was always there! When exactly has this happened and why, I do not know unfortunately
Regards
Frantisek
- DarrenMMay 09, 2017Sr. NETGEAR Moderator
There is a known issue with the no internet connect errors on the EX7000 a fix is coming in the next firmware update.
DarrenM
- AJCrowley666May 10, 2017Guide
is there an ETA on the firmware
regards
- MrBill_Jun 14, 2017Aspirant
DarrenM wrote:There is a known issue with the no internet connect errors on the EX7000 a fix is coming in the next firmware update.
DarrenM
Same problem as everyone else. EX7000 works correctly, but incorrectly states "Your access point has no Internet access. Check to make sure that your router has an Internet connection." Access Point mode, Hardwired to R7000, configured with static IP: 192.168.1.2.
Adding post specifically for "Email me when someone replies", with the assumption I'll see that email sooner.
