DrCharlesForbin
Apr 17, 2017Apprentice
EX7000 no internet connection
Ok - I'm stumped on this one and I'm not paying $50 for a support call if I cana get a new one for $100. Recently, my EX7000 (in Access Point mode) has been reporting that it has no internet connect...
DrCharlesForbin
May 09, 2017Apprentice
Thank you everyone and Netgear should pay you for your time :-)
- WiltshsMay 09, 2017Guide
DRCharlesFobin - I still like the 6rd tunnel this may be a better option interesting though I set IPv6 to auto and it liked IPv6 to 4.
Report back later
I cannot get 6rd running ISP does not support. So could leave it in IPv6 to 4 but ISP does not support this but it does seem to work?
I could not get Netgear Genie working and able to log into the router befire changing IPv6 to 4 setting and now I can!
So Netgear have gone full IPv6 but not all ISP's can support this so still need to fix this issue.
- AJCrowley666May 09, 2017Guide
i agree, great result and well done to all for taking the time to investigate. sadly my Telstra Cable modem does not seem to give me many options to fix this but i understand native support is around the corner and in the end for me it still works, i just have an incorrect status screen on the access point.
- DrCharlesForbinMay 09, 2017Apprentice
Well, I set up a 6to4 Auto Tunnel on my router, no difference - still blocked. I either have to relay it - anything but 2002 requires a seperate relay - or try a 6rd.
