what_man
Mar 07, 2018Aspirant
EX7000 not assign proper IP to Apple iPhone or iPad
Hi all I am running an Netgear EX7000 wifi extender with a NetComm NF15ACV.TP modem router and am having major difficulties connecting it to my Apple products mainly 2 x iPhone 6s and an iPad Air...
what_man
Mar 09, 2018Aspirant
Hi, I'll check the firmware on the replacement extender later on, but on my original extender I had the latest version at the time and still had no connectivity. What channels do you suggest, Iv tried 1 and 6. Doesn't setting up as an AP involve a wired connection between extender and modem? If that is the case I don't have an option to do that.
Thanks
Thanks
jvasanth1984
Mar 09, 2018Virtuoso
Hi what_man,
Yes. It has to be wired to Router for time being to set it up as AP. This is just to isolate if its not connecting in extender mode only or in AP mode too.
- what_manMar 09, 2018Aspirant
Hi, so Iv just updated to the latest firmware v1.0.0.62_1.0.122
I connected it directly to the modem via cable and my it assigned my iPhone the correct range ip address and I was able to get on the internet (I kept it as an extender I didnt set it up as an AP)
I disconnected the wire and put it back to its spot which is about 10m away with a simple plasterboard, timber wall and it has reverted back to its old tricks.
Iv attached a screenshot of the IP's its assigning
Thanks
- jvasanth1984Mar 10, 2018Virtuoso
Hi what_man,
Did you tried modifying wireless channel on Gateway? How about if you try connecting it to 5GEXT network after firmware update? Try to reset and reconfigure it if issue persist since you have upgraded firmware. Lets see if that helps.
- what_manMar 21, 2018Aspirant
Hi, how do you go about modifying the wireless channel, and what channel should I change to then. I have changed the channel 1, 6, 9 in the modem recommended by the supplier. Neither of the bands work at assigning the proper IP address, even though I have updated both the modem and extender.
