FranklySpeaking
Sep 17, 2018Aspirant
EX7000 Range Extender Drops Devices and SSID Not Available after several hours of operation
I am running the latest firmware on both the router and extender.
Issue that I am experiencing is that after several hours or days of operation, my devices that use the extender become disconne...
- Sep 19, 2018
Hi FranklySpeaking,
When you are able to, you can try doing a factory reset as we usually recommend after a firmware update. Please keep us posted on the results and your observations.
Dexter
Community Team
DexterJB
Sep 17, 2018NETGEAR Moderator
Hi FranklySpeaking,
Welcome to the community!
1. Please indicate the exact firmware version of the extender.
2. Is the extender configured in AP mode or extender mode?
3. What is the status of the extender LEDs when the connection drops?
4. Have you tried resetting the extender?
Dexter
Community Team
FranklySpeaking
Sep 18, 2018Aspirant
Thanks for the warm welcome Dexter and for the assistance. Below are my responses...
<I will provide the exact version as soon as possible - I am currently away. I confirmed it was running the latest FW version available to the public as of 2 days ago. After it upgraded, I checked again and the EX7000 responded that there were no newer versions available>
<extender mode>
<I will get that when I return - all the devices have gone offline again so it is currently in a failure state. If I recall correctly, the 2G light was slowly blinking between green and white when it is failed>
<I have re-performed "Set Up" but have not "Reset" the EX7000.>
