FranklySpeaking
Sep 17, 2018Aspirant
EX7000 Range Extender Drops Devices and SSID Not Available after several hours of operation
I am running the latest firmware on both the router and extender.
Issue that I am experiencing is that after several hours or days of operation, my devices that use the extender become disconne...
- Sep 19, 2018
Hi FranklySpeaking,
When you are able to, you can try doing a factory reset as we usually recommend after a firmware update. Please keep us posted on the results and your observations.
Dexter
Community Team
DexterJB
Sep 17, 2018NETGEAR Moderator
Hi FranklySpeaking,
Welcome to the community!
1. Please indicate the exact firmware version of the extender.
2. Is the extender configured in AP mode or extender mode?
3. What is the status of the extender LEDs when the connection drops?
4. Have you tried resetting the extender?
Dexter
Community Team
DexterJB
Sep 19, 2018NETGEAR Moderator
Hi FranklySpeaking,
Dexter
Community Team
- DexterJBSep 24, 2018NETGEAR Moderator
Hi FranklySpeaking,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- FranklySpeakingSep 28, 2018Aspirant
Yes... still having multiple issues.
Firmware version is V1.0.1.164 and I have reset the router.
Sometimes, even after immediately restrarting, there is no 2G network being broadcast.
After a few hours of operation, devices will drop but there is still a 2G network being broadcast. We I connect to "mywifi" to check the status, I receive an error message that states "Checking JS support" and am unable to connect.
The reliability of the device seems to be getting worse.
