LarOz
Oct 03, 2018Initiate
EX7000 WiFi Extender Firmware Update causing constant restarts
I updated the firmware on my Nighthawk EX7000 WiFi extender to Firmware Version 1.0.1.78 from 1.0.0.66. I left the settings the same without enabling any new featuers (One WiFi Name, Smart Connect, a...
jferra1016
Oct 05, 2018Tutor
Same issue here. I did a factory reset. Well at lest that what the software let me select. And I did NOT load any new/current software and it still is having same issue. Constantly resetting at Radom times. Did you down load older version to laptop. And hard connect the wifi router to your network when you uploaded the firmware?
- LarOzOct 07, 2018Initiate
I downloaded the previous firmware onto my PC and uploaded when connecting to WiFi, but connecting with a LAN cable should work fine as well.
