LarOz
Oct 03, 2018Initiate
EX7000 WiFi Extender Firmware Update causing constant restarts
I updated the firmware on my Nighthawk EX7000 WiFi extender to Firmware Version 1.0.1.78 from 1.0.0.66. I left the settings the same without enabling any new featuers (One WiFi Name, Smart Connect, a...
GuGu2077
Oct 09, 2018Tutor
I had this issue as well immediately after upgrading to 1.0.1.78
The internet would drop out first followed by a reboot a few seconds later. It was happening every hour or even less.
Disabling SmartConnect didn't resolve the issue; was already disabled as I don't use the WiFi features. I have it setup to connect to my router via 5Ghz connection and distribute it via LAN. I use this setup instead of Powerline adapters, WiFi adapters or running cable. Works great.
What did fix the issue was rolling back to the previous firmware version 1.0.0.66
