gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
JMW001
Oct 03, 2018Star
Definitely - i've been using mine for a couple years without issue - since upgrading to newest firmware it's essentially now a broken device
gliu
Oct 03, 2018Guide
Hi, thx for reply
Just confirming you didnt see issue until upgrading latest firmware?
rgds
- JMW001Oct 03, 2018Star
Absolutely not - i'd been using the extender happily for a while. I happened to change broadband providers recently and as part of that went into the setup to change the wifi source. It suggested the update, applied it and PC's connect ok but no mobile devices can (android/ios)
Just downgraded it to 1.0.062 - resetting it all up from factor reset to see if it helps
Ok ...can confirm that restoring it to 1.0.062 and doing full factory reset and reconfig has 'fixed' the issue.
Update --- it 'fixes' it for a short time but it's gone again ... again - PC's seem ok but mobile devices are struggling
- schumakuOct 03, 2018Guru - Experienced User
Ensure the primary wireless (your Linksys) is rebooted, along with the extender.
- gliuOct 03, 2018Guide
Hi All
I have reverted to 1.0.6.6 and now stable again. Yes, had to do factory default else it wouldn't just let you downgrade. thx for suggestion.
Is there anyway get Netgear involved so they are aware of issue? My support contract already expired
rgds
