gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
gliu
Oct 03, 2018Guide
Hi, thx for reply
Just confirming you didnt see issue until upgrading latest firmware?
rgds
JMW001
Oct 03, 2018Star
Absolutely not - i'd been using the extender happily for a while. I happened to change broadband providers recently and as part of that went into the setup to change the wifi source. It suggested the update, applied it and PC's connect ok but no mobile devices can (android/ios)
Just downgraded it to 1.0.062 - resetting it all up from factor reset to see if it helps
