gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
schumaku
Mar 18, 2019Guru - Experienced User
We still experience (EX7000 in AP mode, .157_test) that after some uptime, e.g. Windows 10 Intel Centrino Wireless N 2230 systems are loosing the connection and can no longer associate. Got .159_test meanwhile, but now not near to that EX7000 customer site.
Few other oddities - using mywifiext.net or the like does show a page claiming there are multiple extenders on the network - what is definitively not the case.
LordPurple
Mar 19, 2019Star
I did not have much luck with the new firmware, which I got from Christian. After it was loaded, the extender factory reset, reconfigured - no devices could successfully attach to the extender - meaning, they could connect to the 2G or 5G WiFi network (layer 1/2) but were not given a routable DHCP address (layer 3) so they would show "No internet connection". The link from the extender to the base router (Netgear C3700) was fine, as I was able to log into the extender from the router network and the status page showed everything normal. This is basically the same pathology I had with the last (bad) firmware. Several extender reboots and factory resets as well as a reset of the base router did not help, so I've reverted to the previous (1.0.0.66) version and all is well again. I reported my experience to Christian, who did say there may be another test version soon.
- drdantruMar 19, 2019Tutor
thanks
- FURRYe38Mar 19, 2019Guru - Experienced User
Can you downgrad the EX to the last working FW version?
- LordPurpleMar 19, 2019Star
Yes - that is what I said above - after the test FW did not work, I reverted to the "1.0.0.66" version. As long as you can connect to the extender, you can downgrade the FW.
Ah ok, kewl. Hopefully next FW will fix what ever is broke in the last version. :smileyfrustrated:
