gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
JeroenVH
Mar 30, 2020Aspirant
So, small update:
Everything went well for 3 days until my wife connected to the extender by cable with her mac book from work, thats when it kicked the bucket again.
Not sure what that is about but I'm wondering if giving her mac book a static IP might help, going to try it later.
On the bright side, my desktop which I connect to the extender with via cable had a flawless connection for the whole weekend since I gave the extender a static IP in my router settings.
Kind regards,
J
- gliuMar 30, 2020Guide
The extender appears to still have intermittent DHCP issue. When this occurrs, any new device that tries get IP via extender be it wired/wireless wont be able to get IP and hence, access your home network. Note when this occurs, other devices that are connected to extender still able to ping my ISP gateway so unicast traffic is still ok and my extender is still connected to main AP. So issue is specifically somehwere in DHCP DORA process that is not working on the extender. When this occurs, I walk within range of my main AP and connect to it instead. I can then get IP and everything ok. Next thing I did was power on/off extender only, and connected to it instead. Now also able get IP.
Next time you have this issue, try adding static IP to your device and see if you can access internet. This will confirm if your seeing same issue. Suggest you also set DHCP reservation to a long time so you dont get kick out when it tries to renewal after expiry while this issue is present in latest firmware
- JeroenVHApr 08, 2020Aspirant
Hi Gliu,
Thank you for all the tips, I will give them a shot.
Things worked ok for a while but things shifted for the worse with multiple shutdowns a day now, this thing is driving me insane.
Do you set the static IP and DHCP reservation on your main router or on the extender?
Often when I restart the extender it refuses to connect to the 5G network and I have to set it up all over again.
I noticed that when things go south I cannot connect to my main router anymore but can still connect to my extender via its IP address in browser.
I'm wondering what that is about.
Kind regards,
J- JeroenVHApr 08, 2020Aspirant
Lol, great, Netgear apparently does not give an option to extend my DHCP lease time... on my $300 router.
How is this possible??? What in the world are they thinking...
This is becoming a rather frustrating experience making me want to switch to another brand completely
