gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
JeroenVH
Apr 09, 2020Aspirant
Hi Gliu,
Thank you for all the tips, I will give them a shot.
Things worked ok for a while but things shifted for the worse with multiple shutdowns a day now, this thing is driving me insane.
Do you set the static IP and DHCP reservation on your main router or on the extender?
Often when I restart the extender it refuses to connect to the 5G network and I have to set it up all over again.
I noticed that when things go south I cannot connect to my main router anymore but can still connect to my extender via its IP address in browser.
I'm wondering what that is about.
Kind regards,
J
gliu
Apr 09, 2020Guide
When u setup extender, pretty sure there is no option to set static IP. So instead I set the DHCP reservation for the extender MAC address to always use provide same IP. I noted earlier comment by somene else his netgear not able to set lease time. I dont have issue on my main AP which is old Linksys
See comments inline
>>I assume you bave resonable signal receive from main AP on your 5G band. If not, that could be your problem. My extender can connect on 5G band but signal noise ratio is very bad. my extender is on third floor of a house which is double brick. Unfortunately only way get reliable connection is to use 2.4 band for the backhaul. Understand this decrease speed for users connected to extender but thats only option I have besides going down mesh path.
>>that is expected. Its only your extender that has lost its connection to the main AP
Only other issue can see besides the DHCP I have is if u have good signal to main AP, scan frequency and make sure no one close by is using the same band. If needed, change the band used or can try using 2.4G band "choose spectrum no one close by using" and see if you get a more stable connection between extender and main AP. 2.4G band is quite crowded and not many to choose from. Just see option helps
- JeroenVHApr 13, 2020Aspirant
Hey Gliu,
Thanks for all the info.
Yes I have pretty decent 5G connection to my router, the signal strenght is around 70% and is capable to deliver me 350mbps when connected.
I forgot to mention but yes the signal frequencies I make my router use are ones that are not used in my immediate surroundings to have almost no interference.
This weekend I spent some time handing out static IP's to all the devices in the house to make sure there is no problem with that but now the extender chose to just completely ignore that and hand out its own ID's.
Router:
02:0F:B5:5B:5D:E5 - 192.168.1.3
02:0F:B5:CF:54:A2 - 192.168.1.4
Extender:
02:0F:B5:5B:5D:E5 - 192.168.1.20
02:0F:B5:CF:54:A2 - 192.168.1.15
I have tried resetting the extender, resetting to factory, restarting PC's, renewing IP's via CMD,... nothing helps.
They are stuck on those IP adresses now.
The interesting part is that this only happens to wired in devices, the wifi devices received the right IP address set from router straight away when I reconnect them to the extender.- JeroenVHApr 13, 2020Aspirant
Nevermind, the wifi extender just does not give a rats *ss and assigns any IP address it wants to wifi devices too.
I feel this is gonna be a never ending headache... - gliuApr 13, 2020Guide
I dont think the extender "in extender mode" can actually hand out IP. It doesnt act as a DHCP server. Have u double confirmed the IP is handed out by extender or your Main AP. As an example, when I go to my main AP, I can see in the clients list all IP address AP has handed out.
Assuming your extender is handling out IP as you say, just make sure the pool its providing isnt the same one your main AP is providing else u will you may get duplicate IP. You prob dont want to have 2 devices in same subnet handling out the same pool IP address. In enterprise environment you typically have 2 DHCP servers like windows. The IP given is always the 1st DHCP server that responds and the other server will see this.
Lastly, there is an option to set a static IP on extender so that extender is always using same IP. Essentially same as what I am doing on main AP providing the same lease to extender.
