gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
VS228
Jul 05, 2020Tutor
Hello All
Anyone tried the new firmware 1.0.1.86 - Hot Fix. I am using 1.0.0.68_1.0.128, since all newer firmwares have signal drop issues.
Cheers
VS
VS228
Jul 06, 2020Tutor
Installed the new Firmware Version 1.0.1.86 - Hot Fix this morning and it's working beautifully so far. Will keep everyone posted if any problems are encountered.
VS
- sloanishJul 06, 2020Aspirant
What is your setup?
I tried it wirelessly with just 2G extended and still had drop and slow issues.
- VS228Jul 06, 2020Tutor
I think the trick is to avoid using the One WiFi mesh feature.
I have a 2.4GHz and a 5GHz network (with 2 different names) on the main router. The Netgear extends both keeping the same names and passwords for both networks.
- RJ_NZDec 27, 2020Tutor
So I had an email from Netgear to upgrade the software on my Wi-fi range extender which I did and it immediately went into intermittent faliures. I'm not going through that pain again. Reverted back to EX7000-V1.0.0.66_1.0.126 and it's running fine again. I really wish they would sort the issues out as I want to apply the security patches.
FYI setup is Apple Airport running one SSID on 2.4 & 5G, EX7000 extending to two different SSID's (one on 2.4 and one on 5G - both different to the Apple SSID). This works well on the above firmware but fails miserably on all upgrades that I have tried since.
