baR2D2thefirst
Nov 18, 2018Guide
EX7000 wired devices disconnect
Weirdest thing, my wired smart TV gets disconnected all the time, but all the wireless connected devices are fine.
I connect a laptop wired to test and the same thing happens, so not the TV that is...
- Nov 28, 2018Downgraded 1 version just now.
Will let you know!
DexterJB
Nov 18, 2018NETGEAR Moderator
Hi baR2D2thefirst,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
- baR2D2thefirstNov 28, 2018Guide
Sorry, not sure what to do with a PM that asks for my phone number.
After doing more tests I see that all connected devices get disconnected, both wifi and wired.
It started after the last firmware update! Can i revert back to earlier version?
This expensive extender is worthless to me at the moment...
- czrtstNov 28, 2018Aspirant
I had exactly the same same problem since the last last firmware update.
Had to restart the extender every few days.... no connection possible, wired or via wifi.
useless for now.
reset the RE doesnt help.!
- StephenBNov 28, 2018Guru - Experienced User
Did you downgrade back to 1.0.0.66?
- baR2D2thefirstNov 28, 2018GuideDowngraded 1 version just now.
Will let you know!
