baR2D2thefirst
Nov 18, 2018Guide
EX7000 wired devices disconnect
Weirdest thing, my wired smart TV gets disconnected all the time, but all the wireless connected devices are fine.
I connect a laptop wired to test and the same thing happens, so not the TV that is...
- Nov 28, 2018Downgraded 1 version just now.
Will let you know!
DexterJB
Nov 18, 2018NETGEAR Moderator
Hi baR2D2thefirst,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
czrtst
Nov 28, 2018Aspirant
I had exactly the same same problem since the last last firmware update.
Had to restart the extender every few days.... no connection possible, wired or via wifi.
useless for now.
reset the RE doesnt help.!
- StephenBNov 28, 2018Guru - Experienced User
Did you downgrade back to 1.0.0.66?
- baR2D2thefirstNov 28, 2018GuideDowngraded 1 version just now.
Will let you know!- baR2D2thefirstNov 29, 2018Guide
Gee! Good thing we can downgrade, connections seem stable again, will test some more...
HTH can Netgear give out faulty firmware?
:robotmad:
- baR2D2thefirstDec 23, 2018Guide
yes, downgrading is the solution.
- 168billDec 27, 2018Luminary
Had exactly the same problems and also resolved them by reverting to the previous firmware version.
There have been a number of threads on this issue, most of which have been marked as solved and closed to further posts, but when you look at the 'solution', it is always reverting to previous firmware version. This is NOT a solution, merely a temporary workaround.
Isn't it about time Netgear acknowledge that there is clearly a problem and actually do something about providing a real solution?
But I guess marking all the threads as solved improves their stats..........
Bill.
