baR2D2thefirst
Nov 18, 2018Guide
EX7000 wired devices disconnect
Weirdest thing, my wired smart TV gets disconnected all the time, but all the wireless connected devices are fine.
I connect a laptop wired to test and the same thing happens, so not the TV that is...
- Nov 28, 2018Downgraded 1 version just now.
Will let you know!
Nov 28, 2018Guru - Experienced User
czrtst wrote:
I had exactly the same same problem since the last last firmware update.
Had to restart the extender every few days.... no connection possible, wired or via wifi.
Did you downgrade back to 1.0.0.66?
baR2D2thefirst
Nov 28, 2018Guide
Will let you know!
Will let you know!
- baR2D2thefirstNov 29, 2018Guide
Gee! Good thing we can downgrade, connections seem stable again, will test some more...
HTH can Netgear give out faulty firmware?
:robotmad:
- baR2D2thefirstDec 23, 2018Guide
Downgrading firmware is the solution.
