baR2D2thefirst
Nov 18, 2018Guide
EX7000 wired devices disconnect
Weirdest thing, my wired smart TV gets disconnected all the time, but all the wireless connected devices are fine.
I connect a laptop wired to test and the same thing happens, so not the TV that is...
- Nov 28, 2018Downgraded 1 version just now.
Will let you know!
baR2D2thefirst
Dec 23, 2018Guide
yes, downgrading is the solution.
168bill
Dec 27, 2018Luminary
Had exactly the same problems and also resolved them by reverting to the previous firmware version.
There have been a number of threads on this issue, most of which have been marked as solved and closed to further posts, but when you look at the 'solution', it is always reverting to previous firmware version. This is NOT a solution, merely a temporary workaround.
Isn't it about time Netgear acknowledge that there is clearly a problem and actually do something about providing a real solution?
But I guess marking all the threads as solved improves their stats..........
Bill.
