f1dad
Mar 26, 2017Tutor
EX7000 wired ethernet ports operating at 100 Mbps not 1 Gbps
I'm trying to work out why my Windows 10 PC is getting a link speed of just 100Mbps even though its connecting via it's Realtek GBE adapter using a Cat.6 cable. I've changed the Realtek adapter sett...
schumaku
Mar 26, 2017Guru - Experienced User
Double and tripple check the port(s) and the cable.
Another popular problem on a bunch of GBE interfaces are borked or old drivers. Have an eye if oyur RTL8xxx is coevered here -> http://www.realtek.com.tw/Downloads/downloadsView.aspx?Conn=4&DownTypeID=3&Langid=1&Level=5&PFid=5&PNid=13
- f1dadMar 27, 2017Tutor
Thanks. Updating the drivers was one of the first things I tried. Realtek have an Ethernet diagnostic tool which can give readouts on the cable wiring pairs which was giving some intermittent results. It looks like I've got a faulty port on the PC. Some of the contacts aren't as prominent as others. With a little coaxing I've managed to get a good connection and 1Gbps. I suspect it may not last.
