tomasblanco
Dec 03, 2018Aspirant
EX7000 Won't Connect to Certain Websites (AC1900 WiFi Range Extender)
Two days ago my AC1900 WiFi Range Extender stopped connecting to a number of different websites (i.e. espn.com, bing.com, rollingstone.com, etc) across several different devices - i.e. macbook pro, h...
Toweren
Feb 25, 2019Initiate
A few months ago I updated my router (supplied by provider not Netgear) and suddenly I was unable to access most websites whenever I used the EX7000 as an extender. Some could be accessed, while most, e.g. amazon, argos, etc., could not be accessed - responding with a dns error. I trawled the internet and changed IP and DNS settings galore but to no avail. Nothing was going through the EX7000 as an extender - not my iphones, PC, laptops, nothing. Eventually I had to disconnect the EX7000 and leave it idle under the desk, just gathering dust. I was sure that I'd never be any use to me with the new router, then I came accross this thread and the suggestion regarding the firmware. I plugged the EX7000 back in, noted that my firmware was the most recent one 1.0.0.768 or something (must have updated it around the time I installed the new router), so I downloaded the previous firmware 1.0.0.66 and loaded it. Bingo! Everything is working a treat. So, for me, the solution came from backtracking on the firmware.
Bburke
Feb 11, 2020Initiate
Hello,
Just curious. How were you able to download the firmware? I can't download the firmware because of the original issue -- I can't even go to mywifiext .net when setting up the router.
Thanks
