Tobraham
Feb 11, 2018Aspirant
EX7000 wont work with VPN
I'm using an Arris Surfboard modem with the EX7000 extender. My mobile device uses fSecure Freedome as a VPN. Everything works fine when I connect to the modem directly via Wi-Fi. When I connect th...
- Oct 15, 2018
Sorry, Stephen, I tend to use 'router' and 'extender' interchangeably by mistake in a hurry. Yes, the router was not assigning an IPv4 address to my device,
I am using the very latest firmware, Firmware Version: V1.0.1.78_1.0.140.
I did have the router set to "Dynamically get IP Address From Router'.
I solved my problem late last night. Here's what was happening:
By having my extender acquire an IP address from the router, the extender was also copying ( or being dynamically provided) the DNS address of Comcast's servers for DNS lookups. This clearly was not working so I focused my attention on DNS issues.
First I switched over to using a static IP address. I copied the dynamically-allocated info from my current connection and pasted them into the staic information fields. I also reserved that IP address on the router so there would be no interference down the road.
Then I looked at the gateway info and it dawned on me that the router is the gateway to outside world and for this to work properly the extender needs to use the router's IP address (192.168.0.1) as the gateway, AND if that's the case, it would make sense that the Primary DNS source for the extender should also be the router and not Comcast. So I changed my Primary DNS on the extender from Comcast's 75.75.75.75 to the local gateway of 192.168.0.1.
Boom. All sites I was originally unable to access before were immediately functioning. I could now use my VPN when connected to the extender (because my VPN company's servers could now be reached). I checked my Firestick and it was now just showing `Connected` and not `Connected with problems`.
So, my hunch was right. DNS was the booger. What a pain in my side.
StephenB wrote:
Tobraham wrote:
See my latest updates on this matter. Devices are not getting assigned IPv4 addresses by the extender. Those with IPv6-only addresses can only reach IPv6-capable web sites. So we're back to the Netgear now.
Just to clarify: Devices connected through the extender are not getting assigned IPv4 addresses by the router. The extender isn't assigning addresses.
Can you try configuring a static IPv4 address on one device, and see if that gives you full connectivity?
Also, what firmware are you running?
DexterJB
Feb 14, 2018NETGEAR Moderator
Hi Tobraham,
1. Does the issue persist on your non-mobile devices (PC's, Mac)?
2. What operating system does your device/s use (Android, iOS)?
3. What is the firmware version of the extender?
4. Do you have the extender set to "Dynamically get IP Address from the router" or "Use static IP Address"?
5. Have you tried other firmware versions for the extender?
Dexter
Community Team
Tobraham
Feb 19, 2018Aspirant
Hi, Dexter!
Q: What operating system does your device/s use (Android, iOS)?
A: I know the mobile devices in my home both display the same issue - one is an iOS and one is an Android. The Android shows the VPN is on (church key icon) as if it's connected but as soon as I send a request for a web page, for example, the VPN icon disappears and of course I can't connect to the page since the VPN blocks traffic when it loses connection. The iOS behaves slightly differently in that it shows it has a wifi connection and never shows the VPN icon and gets no connection to the outside world.
Q: Does the issue persist on your non-mobile devices (PC's, Mac)?
Our Firesticks show that they are connected to the extender but they often say 'connected with errors' and don't actually load the home page or any videos. The laptop has the fewest issues but still has more trouble with the extender than the main router.
If I reboot the extender, it will work for a very brief period of time but by the end of the day if not within an hour, the same issue begin to appear again.
Also, sometimes whebn I turn off the VPN on my Android and connect to the extender, I show that I'm connected but I can't open the mywifiext.net URL. Right now my Android is showing
Status: connected
Signal Strength: Excellent
Link Speed: 86 Mbps
Frequency: 2.4 GHZ
Security: WPA2 PSK
but I can't open mywifiext.net
I'll answer the remaining questions in a minute when I can reconnect to the extender.
