Abdullellah
Jan 14, 2020Aspirant
EX7000
All lights flashing!!! (Red, green and white)
And it’s not working.I do reset but the same
Thats usually not a good sign.
Be specific. You said they're all flashing. which ones are flashing which color.
When you tried reset, did you push and hold reset for 7-15 seconds? Potentially up to 30 seconds?
Potentially you could try a tftp recovery procedure but it sounds like a hardware failure.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
How long have you had it? Is it still within warranty?
- AbdullellahAspirantActually the modem not working and i try to push and hold reset for 7-15 sec and 30 sec
I bought before 2 years and more and the warranty was finish- plemansGuru - Experienced User
I bought before 2 years and more and the warranty was finishThe modem isn't working?
What modem? You listed the ex7000 which is a range extender.
what router are you using?
maybe some better details of what devices you're using and exactly whats going on, can help.
- rob1966ertAspirant
I have a netgear ex7000 and I can't remember the password to sign into the wifi on cmputer or phone,, how do you reset
ex7000 has an ethernet port on it. you can connect via that route and then log into the device and see what the ssid/password is.
Or you can push and hold reset while powered on for 7-15 seconds. the lights should change. this'll get you back to factory
