Just_y
Sep 12, 2017Aspirant
EX7300 - Data lag
Hi guys
I needed to extend my standard ISP modem/router wifi range so I bought the EX7300 for this specific use.
I plugged in the EX7300 and set it up - got the internet connection straight away - all good from that perspective.
I am using a Frizbox 7390 (v06.53) as modem/router and set up a new SSID for the wifi extender as per their recommandation.
So I have the "A" wifi network provided by my Fritzbox and a "B" wifi network provided by the EX7300 (FastLane mode - 5Ghz in/2.4Ghz out).
My issue is that I cannot upload any file with my "B" wifi network to neither the local network nor any internet cloud service (except Dropbox?!).
I understand this is caused by a misconfiguration within my local network but I can't figured out what to do.
Can someone help me pls?!
Thanks a lot!
- DarrenMSr. NETGEAR Moderator
Hello Just_y
Could be a port forwarding issue have you checked if any of those file services need a port to be open?
DarrenM
- Just_yAspirant
Thanks DarrenM for your message.
Can be a port forwarding issue indeed but this also happen in my local network.As far as I understand port forwarding, it works from an internet service to a device in a local network, right?
(against devices in a local network)Here is my config again:
Fritzbox 7390 (ISP modem/router) EX7300/AC2200- wifi network 1 - wifi network 2
- smart TV
- TV box
- PS4
- NAS 1
- NAS 2
I can't even upload any file on my NASs.
I am pretty sure it's not a compatibility issue and I know I am doing smtg wrong but can't get where.
Thanks for your help,y
