fatburger1849's avatar
Apr 24, 2024
EX7300 - do firmware updates have to be applied sequentially
Do the firmware updates have to be applied sequentially? There are a LOT of them since the version I have including some that seem to relate to upgrading to a mesh network. Given that the size of each seems relative consistent (in the 14MB range) it seems like they're replacements rather than updates. Thoughts?
  • Answered my own question. They're cumulative - I went directly from version
    V1.0.1.60 to version V1.0.2.164 and it works fine.
    • plemans's avatar
      Glad it worked for you!
      There's a few routers that need a stepped approach if the firmware expands the provisioning. Much less likely on an extender.
      But I'd mark yours as solved so others aren't still trying to fix it 🙂 good work
