DanielGarzaB
Jan 25, 2017Guide
EX7300 drops internet connectivity for almost all my computers
I have 3 EX7300 as access point in my office.
One EX7300 seems faulty. All the people who are connected to the Wifi signal will get disconnected now and then out of nowhere. Seems like the SSID dissapears and they just get re-connected
This is getting really messy. Ive tried everything. First firmware, latest, in between the first and latest. Wifi channel is different from the router channel. Changed chinnels. Ive tried pretty much everything and still it aint working properly
What can I do?
Thanks a lot
- DarrenMSr. NETGEAR Moderator
Hello DanielGarzaB
I would suggest factory reset of the extender then set it up again and if it is still acting up I would contact support so they can replace the unit if its under warranty.
DarrenM
Thanks a lot
Ive done factory reset, firmware upgrade to the latest, downgrade to the first, etc... still the problem is there
I guess ill need to contact the support
