NX
Sep 15, 2016Initiate
EX7300 drops internet connectivity
Hi there, so I purchased myself an EX7300. Manual setup went all well. My problem is, that, although Windows states that it has internet access and and the wireless signal is at the highest l...
- Sep 17, 2016
I think I solved the problem by giving the router a fixed wLAN channel (48) and the repeater another (40). Haven't had this issue since.
Noobie
Sep 23, 2016Aspirant
I've been having the similar issues (same model, same firmware version). I've modified the settings so that router and extender have different channel numbers. Hope this works for me as well.
When I called NETGEAR support, they've asked me downgrade the firmware to the initial release.. Rather than downgrading the firmware, I came to this site, and found your message. Thanks for posting your details.
agassner
Oct 12, 2016Aspirant
I have the same issue with the same model and firmware and can't find the solution!
I don't have the option to change the WiFi Channel.
Help!
