NX
Sep 15, 2016Initiate
EX7300 drops internet connectivity
Hi there, so I purchased myself an EX7300. Manual setup went all well. My problem is, that, although Windows states that it has internet access and and the wireless signal is at the highest l...
- Sep 17, 2016
I think I solved the problem by giving the router a fixed wLAN channel (48) and the repeater another (40). Haven't had this issue since.
agassner
Oct 12, 2016Aspirant
I have the same issue with the same model and firmware and can't find the solution!
I don't have the option to change the WiFi Channel.
Help!
