Mykola
Apr 22, 2017Follower
EX7300 extend only 2,4Ghz
I have EX7300 as an extender and R7800 as an wifi router
when i setup EX7300 it work only for 2,4 Ghz network
5Ghz network has Connection Status: Disconnected
Connection to Existing Network (2.4GHz)
Signal Strength: 214Mbps
Name (SSID): SOSKA Chavdar
Channel: 4
Connection Status: Connected
Connection to Existing Network (5GHz)
Signal Strength: 0Mbps
Name (SSID): Soska Chavdar 5g
Extender WiFi Status (2.4GHz)
Name (SSID): SOSKA Chavdar_2GEXT
Channel: 4
Region: Russia
Wireless mode: Up to 450Mbps
Wireless AP: ON
Broadcast Name: ON
WPS: Configured
Security Type: WPA2-PSK[AES]
Extender WiFi Status (5GHz)
Name (SSID): Soska Chavdar 5g_5GEXT
Channel: 44(s) + 48(p)
Region: Russia
Wireless mode: Up to 1733 Mbps
Wireless AP: ON
Broadcast Name: ON
WPS: Configured
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Mykola
Is the extender to far away from the router to pick up the 5ghz? also do you have the correct settings and not using fastlane to only use 2.4ghz?
DarrenM
