jeffmotes
Jan 09, 2017Aspirant
EX7300 Extender or Access Point?
Can anyone give me the best setup for extending the wifi range of my current router. I bought the EX7300. Should I use it as an extender or access point? What I'm trying to accomplish is being abl...
DarrenM
Jan 11, 2017Sr. NETGEAR Moderator
Hello Jeffmotes
You can not switch between extender and router automatically the only way this would happen is if you lost connection to the network then the device will connect to the strongest signal. If you are wanting auto switching you may want to look at our new router Orbi.
DarrenM
