kjshan
Dec 23, 2019Tutor
EX7300 extender works with iOS and Roku but not Windows
I configured my NetGear extender using the 2G/5G bands and one name/password. However my devices will connect except my Windows computer. I think it my be something in my security settings or IP setti...
- Dec 23, 2019
Have you went into your window's device, "forgot" the network, and tried to reconnect?
What error are you getting?
What spectrum router is it?
do your work laptops connect with a vpn?
Dec 23, 2019Guru - Experienced User
kjshan
Dec 23, 2019Tutor
It appears that forgetting the WiFi network and reconnecting did the trick - thank you for the reminder/tip! I have used this NetGear Extender before, and I guess it remembered when I tried it unsuccessfully in the past. Now we are good to go with all of our devices.
- plemansDec 23, 2019Guru - Experienced UserGlad to hear it worked!
- kjshanJan 01, 2020Tutor
I am still having connectivity issues. It appears my solution was only temporary. My windows laptop and iOS devices are up and running, but the ROKU TVs appear to be having connectivity issues. There are not that many settings a user can change in the setup screen that I am aware of, and I am not a super-techy person. I was just following the directions for "smart setup." I did some reading here on the forum to try to trouble-shoot:
1. One Network Name
2. 2G/5G share passwords
3. Use smart connect
4. Do not use static IP
I know there are other settings to change that are more advanced. Is there something, like the PIN. Is this something that is causing the Roku to fail? I am not having an issue with my Amazon Fire TV.
It is frustrating because it will work for a while and then fail. Maybe it loses connection and then it can't re-connect and doesn't know which network to select? Should I try just using two different networks, and manually switch our other devices?
We really need an extender because of the size and age of our house. The standard modem will not provide service to the second floor, and we can't get cellular coverage in our area without the wifi-enabled service.
If I can't get the AC2200 to work, I may need to look into purchasing a different product like a Google Nest or something. I have read they are easy to configure and work well with Roku.
Thanks!
- plemansJan 01, 2020Guru - Experienced User
How big is your house?
What are the interior walls made up of? Certain materials block wifi more than others.
I read, a while ago, about some of the roku devices having issues with either the higher band 5ghz channels or lower band 5ghz channels. I can't remember which is was. You can try changing the wifi channels on the extender to see if it'd work.
What router are you connecting back to? I know you said spectrum but a model number helps. Some ISP supplied routers are junk.
Have you tried setting a static address for your roku through your primary router?
If you go into your roku (when its working), run roku's network check.
This can tell you important info about how good the connection the roku has to the devices its connecting to.
Another question on layout. Where is the roku in relation to the extender and router? potentially the roku could be trying to connect to the router and not the extender and because of distance/poor signal then be having issues. The one ssid name feature works great for most devices but maybe it causes issues with roku devices.
If your house is that big, an Orbi setup works great. I've been running them for years and love how well they funciton.
