kjshan
Dec 23, 2019Tutor
EX7300 extender works with iOS and Roku but not Windows
I configured my NetGear extender using the 2G/5G bands and one name/password. However my devices will connect except my Windows computer. I think it my be something in my security settings or IP setti...
- Dec 23, 2019
Have you went into your window's device, "forgot" the network, and tried to reconnect?
What error are you getting?
What spectrum router is it?
do your work laptops connect with a vpn?
Jan 01, 2020Guru - Experienced User
How big is your house?
What are the interior walls made up of? Certain materials block wifi more than others.
I read, a while ago, about some of the roku devices having issues with either the higher band 5ghz channels or lower band 5ghz channels. I can't remember which is was. You can try changing the wifi channels on the extender to see if it'd work.
What router are you connecting back to? I know you said spectrum but a model number helps. Some ISP supplied routers are junk.
Have you tried setting a static address for your roku through your primary router?
If you go into your roku (when its working), run roku's network check.
This can tell you important info about how good the connection the roku has to the devices its connecting to.
Another question on layout. Where is the roku in relation to the extender and router? potentially the roku could be trying to connect to the router and not the extender and because of distance/poor signal then be having issues. The one ssid name feature works great for most devices but maybe it causes issues with roku devices.
If your house is that big, an Orbi setup works great. I've been running them for years and love how well they funciton.
kjshan
Jan 02, 2020Tutor
The two Roku devices are located in different parts of the house. One is on the second floor and the other is in an adjacent room to the Charter modem. I did try the static IP address but my iOS devices did not seem to like that setting and would not browse using Safari. Our house is from the 1920’s and has really thick plaster and is > 4000 sqft. The Charter modem and router is new but doesn’t have a brand name or model on it. I had the installer put it on top of my kitchen cabinet which is about 9 feet up on the first floor in the center of our house. It is open on the shelf (not closed in a cabinet) so it could broadcast to other rooms.
This is where I had my AT&T fiber equipment located for years and it seemed like a good central spot. We do have a third floor with an old coax line dropping down the second floor TV Den. This is directly above the room where the equipment is residing now. I could have an installer hard-wire it upstairs if that could produce a stronger signal.
I am wondering if I just upgrade to something newer/easier. Perhaps the configuration on the NetGear extender is just not compatible with the variety of our electronics and my novice networking capabilities?
- plemansJan 02, 2020Guru - Experienced User
I think most of your issues is coming from the construction of your house. Plaster lathe is great at blocking wifi. It usually has mortar with a bed of either chicken wire or metal mesh for the mortar to adhere to. both excellent materials at blocking wifi. Especially the 5ghz band which is the best band for wifi streaming.
and its tough to tell you about the charter box. The extender can only be as good as the router. If even the roku that is an adjacent room, is having issues with streaming directly off the charter router, the issue might be both the charter router and the home construction.
Plus 4000 sq ft is a bigger home. I've got 3300sq ft with sheetrock/wood construction and I run a mesh network with multiple satellites for best coverage. You're trying to cover your area with a ISP supplied router and a single extender all while in a large home with walls that make wifi transmission difficult. it sounds like a recipe for issues with streaming
