bacincny
Mar 23, 2020Aspirant
EX7300 no internet
Hi,
Installed the EX7300v2 several times, using both WPS and Network Setup, factory reset between tries. Connects to my router fine, both 2.4Ghz and 5Ghz. But, when I connect a device to the extended WiFi, there is no internet connectivity. Using the Netgear app on my phone shows no internet connection. Reboot after everything was setup didn't work either. I saw a similar post that mentioned router filters. I do not have any filters setup. My router is an Askey Computer Corp DBDC ROUTER RAC2V1K provided by Spectrum.
Any ideas on what else I can try?
Thanks in advance -- Brett
if you look up that router, you're not the only one having issues adding an extender to it.
tp-link/netgear all have had issues connection. I haven't seen any solutions to it.
