Dantecat
Sep 08, 2016Follower
ex7300 router to extender connect
This extender is working well, but I am wondering what is best configuration to use, what are the pros/cons, of router:extender and extender:client. Use both 2.4 and 5 Ghz for both: Use 2.4 from router and 5 to client; or use 5 from router and then 2.4 to client?
Thanks
DC
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Dantecat
That just all depends on the environment you are using it in you would have to experiment to find what works best for you.
DarrenM
