Retired_Member's avatar
Retired_Member
Mar 13, 2018
EX7300 Slow Speeds
I use a Nighthawk X4 WiFi Range Extender; the only problem is that the speeds are worse when I did a comparasion with my Nighthawk AC1900 WiFi Cable Modem Router. I'm aware it is normal that the EXT ...
  • jvasanth1984's avatar
    jvasanth1984
    Mar 15, 2018
    Hi Retired_Member,
                             Speed depends on distance, obstacles as well as interference devices including devices on the network and their utilization of speed. In AP mode, if you can try to minimize the distance between devices and AP, you could witness better speed compared to extender mode since distance might be more.
