Retired_Member
Mar 13, 2018EX7300 Slow Speeds
I use a Nighthawk X4 WiFi Range Extender; the only problem is that the speeds are worse when I did a comparasion with my Nighthawk AC1900 WiFi Cable Modem Router. I'm aware it is normal that the EXT ...
- Mar 15, 2018
Hi Retired_Member,
Speed depends on distance, obstacles as well as interference devices including devices on the network and their utilization of speed. In AP mode, if you can try to minimize the distance between devices and AP, you could witness better speed compared to extender mode since distance might be more.
Retired_Member
Mar 15, 2018Yes, I have updated the firmware. The speed are still looking like they've been cut in half. I have tried changing to Fast Lane. There isn't a significant difference. What about the idea of using PowerLine to make it an access point?
jvasanth1984
Mar 15, 2018Virtuoso
Hi Retired_Member,
Did you tried modifying wireless channel on Router to see if that make a change? Yes, you can use this as AP with a powerline adapter, but speed might impact a bit when you connect devices wireless.
- Retired_MemberMar 15, 2018I have used the NETGEAR WiFi Analytics app to see which is the best channel to be on. They were already on good channels on default. I have noticed speeds are affected when there are more wireless devices connected to WiFi even though they're not directly connected to the extender.
- jvasanth1984Mar 15, 2018Virtuoso
Hi Retired_Member,
Yes. Thats true. If there are more devices which is utilizing the overall internet speed, it'll drop since it is been shared by all devices.
So the EXT network is slower compared to the normal WiFi network. Is it better to use EX7300 in access point mode rather than extender mode? Or there isn't a significant difference in speed performance?
