geo_rule
May 02, 2016Aspirant
EX7300 Won't Connect on 5GHz Band
Just received this today. Installation went okay, but no clients will attach to 5GHz band, and I tried four different ones --desktop, laptop, tablet, phone. I can see the 5GHz EXT just fine, but not...
geo_rule
May 03, 2016Aspirant
Okay, so this is now resolved. First it got worse --the EX7300 wouldn't connect to the Comcast modem (latest DOCSIS 3 Comcast modem supporting 250MB/s service) on the 5GHz band at all. After a few reboots of the Comcast modem/router, it appears the Comcast wireless router spontaneously (I didn't do it) switched the channels it was broadcasting on. Was previously 36(p) + 44 + 48 on 5GHz. Now it's broadcasting 5GHz on 149 + 153 + 157(p) + 161. . . and that seems to have caused a miraculous healing. Now the EX7300 will not only connect to the modem/wireless router on 5GHz, it's allowing clients to connect to the EX7300 5GHz band with a strong connection and great speeds. Showing 1299MB/s in GENIE, and speedtest.net just gave me well over 150MB/s connecting to the 5GHz band on the EX7300.
So, problem solved for now. Still don't know where the real culprit was (Comcast's modem/wireless router or Netgear's extender), but forcing the channels to change on the 5GHz band from the modem/router solved it.
