geo_rule
May 02, 2016Aspirant
EX7300 Won't Connect on 5GHz Band
Just received this today. Installation went okay, but no clients will attach to 5GHz band, and I tried four different ones --desktop, laptop, tablet, phone. I can see the 5GHz EXT just fine, but not...
ryanmusante
May 16, 2016Aspirant
NOT SOLVED.
I am experiencing problems with the 5GHZ dropping connections after connecting. This problem is definitely not solved. When it does connect successfully, it will not maintain connection and/or it will drag very slowly. I own other extenders with Netgear that do not exhibit this problem on the 5GHZ.
geo_rule
Sorry it's still a problem for you. Did you force the router to change 5GHz channels?
I can only say for me it's been rock solid since I posted my original resolution not quite two weeks ago.
- ryanmusanteMay 16, 2016Aspirant
My router is ASUS RT-AC66U with DD-WRT latest firmware. I've tried nearly every channel with the 5 GHz, save and apply settings and reboot. Than, the extender usually will connect back to the router. My clients connecting to the extender are hit and miss connecting to the extender and if they do connect, it is usually dropped soon after.
