ambersovtrc
May 13, 2022Aspirant
EX7300v2 Extender not found
I've been using the Nighthawk X4 AC2200 WiFi Mesh Extender (Model EX7300v2) for approx. 5 months. Setup was easy and it's been doing the job perfectly. Yesterday, my wifi went out (not sure if it was...
May 13, 2022Guru - Experienced User
What are the led's on it doing?
What firmware is on the extender?
Did you initially try setting it up using wps? If so, by default it sets up using the same ssid as the router. So it won't show up as separate. I don't trust the app very much lately so I'd recommend logging into your router and checking its attached devices page to see if its connected
- ambersovtrcMay 13, 2022Aspirant
Thanks for your response. The only lights that are 'on' on the extender are the power light (steady green) and the light indicating the extender is connected to my phone (also steady green).
I don't believe there is any firmware on the extender (I didn't install any, anyway)
No, I set it up wirelessly with the Nighthawk app. Honestly, I don't know how to log into the router. I lease space from another business and I guarantee they do not know how to log into the router either.
- plemansMay 13, 2022Guru - Experienced User
what router are you connecting it to?
Is that router a business class one or consumer?
- ambersovtrcMay 16, 2022Aspirant
It's a LINKSYS EA6900
Pretty sure it's consumer class
