BigBlue_007
Mar 29, 2018Aspirant
EX7500 - need help to understand link options
Hello, I need some help to simply understand how this thingy works. When I first set it up, I used the manual setup mode. My main router (Non-Netgear) is a dual band device. I use the same SS...
jvasanth1984
Mar 31, 2018Virtuoso
Hi BigBlue_007,
It is designed to extend both bands. WPS failed on one of two instance is what it results in extending 5GHz alone. Try WPS again or use browser method to setup the extender with both bands and check if it works. Also, upgrade firmware of extender to latest and modify wireless channel on your router to have better connectivity to the extender.
- BigBlue_007Apr 06, 2018Aspirant
Thanks!
Firmware was on the latest level already of course. And I had already tested the browser method before, with the results that I had mentioned (repeater was connected to router with both bands but clients connected to the repeater had various issues).
My assumption that the repeater works better with only the 5GHz band connected to the router was wrong. The 2nd info display I posted above (where the repeater is connected to the router using 5GHz only, but at the same time the repeater itself offers both bands for clients) is wrong. Actually, when the repeater is connected to the router using 5GHz only, it also only offers 5GHz band to clients. I noticed this later when I saw that only very few of my devices (those with 5GHz support) connected to the repeater.
What I now did was to execute the browser setup again, but without resetting the repeater and beginning from scratch (tried that before with no luck). I enabled both bands to be repeated (as I did initially when I first set it up), and now it's again connected with both bands to the repeater, but I see no more issues with any of my clients.
Don't know what exactly went wrong intially, but it works now.
Thanks!
- jvasanth1984Apr 06, 2018Virtuoso
Hi BigBlue_007,
Good to know that it works fine now.
