ae6dx00
Nov 05, 2018Guide
EX7500 can not access web interface after firmware upgrade
EX7500 can not access web interface after firmware upgrade. It said it was loading the new firmware then the web page stopped responding. The extender is online and working per its lights. I have ...
SimonB64
Nov 07, 2018Aspirant
Same thing happened to me this past weekend. I saw an update and decided to do it as I was starting to have some connection issues to the extender. The update locked up and I now hav a $200 brick!! Called support and they told me to factory reset and re install which I have already done 8 times now. I STILL cannot get it to connect to the Internet properly and cannot see the log in page (www.wifiext.local). I am out of support warranty by a couple of months but still have hardware warranty. This company has not been very helpful at all with this isssue. something happened during the firmware update and my externder is screwed!!
SimonB64
Dec 04, 2018Aspirant
And its STILL dropping connections!! I have had my ISP round to check and signal is good. It is this extender. Total waste of $200 and I will NOT recommend this plastic brick!!
- ae6dx00Jan 06, 2019Guide
I was finally able to speak to L2 suppoort and solve this. If the extender is using the same wifi network as the riouter you can only access the web interface using its IP address. The mywifiext.local only wortks when the extemnder creates its own network.
- SimonB64Jan 06, 2019Aspirant
Yeah, they did that with me a few weeks ago and I still had problems...then we rolled back to previuos firmware version and all has been good since!! I even access mylocal now, not a static IP address.
- ericafFeb 14, 2019Aspirant
HELP- I think i am having the problems you are having. Yesterday, my extender network stopped recognizing our personalized passwords. I tried everything, finally resorting to a factory reset. The networks no longer appear, nor does NETGEAR_EXT show up at all. I have tried everything but my extender (which lights up well) is GONE.
HELP ME PLEASE
