gresch's avatar
gresch
EX7500 Extender installed, but no connection
The installation seems satisfactory (blue lights for WEP, power and router link), but I can not connect devices to the extended network. I have a Roku stick, Kindle Fire 10, and iPhone7 that I would like to use in the area of low signal. They show the 5Ghz channel in their options but when I select it, neither of the connection lights on the extender come on at all.
1 Reply
  • Hi gresch,
                        Try to disable and enable wifi on devices to see if that helps. Also, check for firmware upgrade if any.
