ae6dx00
Mar 31, 2018Guide
Ex7500 looses connection
I have an EX7500 and a Nighthawk X10. They have worked fine for the last week or so since I got the EX7500. Today the EX7500 router light on far left keeps turning red. Yet I'm able to access mywi...
ae6dx00
Mar 31, 2018Guide
How do I know which channel to use? Router is currently on Auto. Does the extender have its own channel?
If the extender shows disconnected as in my screenshot how am I able to access its settings page?
jvasanth1984
Mar 31, 2018Virtuoso
Hi ae6dx00,
2.4GHz shows disconnected whereas 5GHz is still active, but have weak signal. You can login to it using mywifiext from windows PC or using mywifiext.local from any MAC PC or iOS devices or by IP address of it from android mobile. You cannot change the channel for extender since it reply on router's channel. You can try channels like 1, 6 and 11 for 2.4GHz and 44, 48, 153 for 5GHz. If you have android mobile, you can use wifi analyser app which can help you to identify best channel for your environment.
- ae6dx00Mar 31, 2018Guide
Unfortunatly I only have an iPhone.
- jvasanth1984Mar 31, 2018Virtuoso
Hi ae6dx00,
I would recommend you to try the channels suggested for both bands and see which 1 suits for your environment.
If the extender goes offline how do I get the devices that were connected to it to get an IP address from the router? I used to just have a routrer but now that I have the extender when it goes offline so do a lot of devices.
