carlmuck
Jan 19, 2018Follower
EX7500 not extending 5ghz band
I'm trying to extend a new network. The home network is served by a Ruckus H510. When running the NetGear Genie the 2.4ghz network is found, but the 5ghz network is not. When I try and manually enter...
DarrenM
Jan 24, 2018Sr. NETGEAR Moderator
Have you tried to lower the channel of the 5ghz network on the router?
DarrenM
neco
May 06, 2018Aspirant
I Guess that issue could be the channel used by EX7500, it is 100 or higher (104, 108...) for 5G and some devices don't see it (like Nvidia SHIELD TV).
Use a wifi scanner and check channels.
