DaddyMac2
Oct 17, 2018Tutor
EX7500 Range extender drops connections
I have the EX7500 range extender and the X10 router. The range extender is consistently dropping connections and needs to be re connected to the router to fix. I have tried changing channels and th...
DexterJB
Oct 22, 2018NETGEAR Moderator
Hi DaddyMac2,
Welcome to the community!
1. What is the firmware version of the extender?
2. When the connection drops, are the extender networks (2.4GHz and 5GHz) still visible?
3. Have you tried resetting the extender?
Dexter
Community Team
DexterJB
Oct 23, 2018NETGEAR Moderator
- GibberishNov 19, 2018AspirantI’m running into a similar issue. When extender is plugged in the connection is sporadic. I can always connect to the WiFi but internet access isn’t available. When I unplug the extender all works well but devices in corners of the house or backyard can’t get a good connection.
What is the solution here? - misterchanNov 21, 2018InitiateDexterJB, I also have the same problem. What is the solution? Can you please post on the forum to help others that come afterwards rather than just sending directly to someone’s inbox.
- weltzinbrauJan 13, 2019AspirantSame problem. Please share the recommended fix.
- GibberishJan 13, 2019AspirantNo fix. Resolution was to move my router to a more central location and through the extender in the trash.
