DaddyMac2
Oct 17, 2018Tutor
EX7500 Range extender drops connections
I have the EX7500 range extender and the X10 router. The range extender is consistently dropping connections and needs to be re connected to the router to fix. I have tried changing channels and th...
DexterJB
Oct 23, 2018NETGEAR Moderator
Gibberish
Nov 19, 2018Aspirant
I’m running into a similar issue. When extender is plugged in the connection is sporadic. I can always connect to the WiFi but internet access isn’t available. When I unplug the extender all works well but devices in corners of the house or backyard can’t get a good connection.
What is the solution here?
